Kevin Long
I am hooking up 2 over water pressure tanks (42 gal each) together, for some closed system experiments such as aerating and de-aerating. I would like to run water through the tanks continuously for periods such as 8 hours or longer at 45 psi. I am assuming I will have to pressurize the system to 45 and then turn on the pump to move the water so less stress there. Any suggestions for a durable pump? I assume most lightweight solutions will over heat and maybe a submersible in a tank to stay cool? No idea. Would love to hear ideas for this solution!
Also any ideas on how to use the pump as the source of pressure in one tank while releasing the pressure in the second tank while drawing water from it back in to the pressurized tank?
Thank you!
Thank you!
