DWV System Diagram: Critique my work
lyz
Jun 9, 2021
Arkansas
I am new here and this is my first time posting. Nice to meet you all, and thanks for reading.
I am working on building a bathroom. I am in Arkansas and from what I can find, the codes here are based on the 2006 IPC.
Anyway, I drew up a diagram and this is what I came up with. Does it look ok, or maybe I am crazy? Feel free to advise, critique, laugh, scream, rant, or cry.
Are there some glaring problems that I am missing?
Are my vents in the correct place?
Are my fittings all right?
What placement/fittings would you use instead, where, and why?
Here are two pictures of the space. Below that are two pictures where I have superimposed my plans on top of them. Thanks!
^^From the sink p-trap I am kind of stuck running along the top of the slab towards the shower drain line. I guess I have to have some drops and turns there to meet up with the shower drain line. Do you think it would be better to use two 45s instead of 2 90s to reduce the degree of turn?
Twowaxhack
Professional
Professional
Feb 9, 2021
2,690
1,069
United states
I don’t like the two 90’s offset under the toilet. Try to locate your san tee for the toilet directly over your horizontal to eliminate the two 90’s.
Use 45’s on the 2” rather than 90’s.
Your code may require one 3” vent in the building if there’s not one or if this branch connects to the sewer outside the building foundation.
I don’t have a resource for reference to check your code. If you’re getting permits they’ll want you to draw it anyway....
lyz
Jun 9, 2021
Arkansas
Hi, thanks for your response!
So the offset under the toilet is because of the unfortunate slab situation. I'll upload a picture below:
Since there is no crawlspace under the toilet, I'm hoping to get around it (and not have to go through it) by snaking the system around. It's kind of a weird set up, because there IS a crawlspace under the shower.
JG plumbing
Mar 26, 2021
933
308
Iowa
Can you roll the combo on a 45 and use a 45 for the riser? Also your sink drain doesn't need to be 2". Should be 1.5 I'm not a fan of oversized drains.
lyz
Jun 9, 2021
Arkansas
Hey! Thanks, a roll on the 45 combo with another 45 for the riser would be way better =)
