Cardinale
Hi all it’s been awhile, my question is can I put 2 90deg. elbows replacing the 45deg. fittings at the bottom of the long dry vent pipe where it comes thru the wall To level off the pipe? The short cutoff piece goes to sink and the 2” thru floor (wet vent when sink is draining) Goes to toilet. According what I can find on the web it says not more than a 90 deg fitting on a dry vent. The 90 deg. Fittings would still be above sink. Also would every thing drain ok? Everything would be concealed under vanity. Thanks Gus
