Dropping the large self-feeds
Discussion in 'Plumbing Tools and Equipment' started by WorkingStiff, Feb 26, 2017.
  1. Feb 26, 2017 #1
    WorkingStiff
    WorkingStiff
    WorkingStiff
    Dec 10, 2016
    9
    In the past I used a 2 1/8" self-feed for 1 1/2" ABS, now that I have a set of Blue Boar TCT's carbide hole saw bits that is no longer the case. These things cut through studs like butter and I can stay cordless without having to pull out that heavy ass Hole Hawg. I will probably stay with self-feeds and augers below 1 1/2 but anything larger and it is carbide hole saws for me. You guys the same? or sticking with the self-feeds?
  2. Feb 27, 2017 #2
    phishfood
    phishfood
    phishfood
    Well-Known Member Supporting Member
    Jan 18, 2010
    5,683
    965
    Orlando, FL
    For a hole or a few holes here and there, I will often grab the hole cutters, such as Milwaukee's Bighawg or similar. But for lots of holes cut cleanly without having to mess around with getting the core plugs out, and not having to put any pressure on the drill, nothing I have found beats a self feed powered by a Milwaukee SuperHawg.
  3. Feb 27, 2017 #3
    WorkingStiff
    WorkingStiff
    WorkingStiff
    Dec 10, 2016
    9
    Are you running the cordless SuperHawg? Just curious, been eyeing that one.
  4. Feb 28, 2017 #4
    phishfood
    phishfood
    phishfood
    Jan 18, 2010
    5,683
    965
    Orlando, FL
    No, but I definitely have my eye on that as well!
    The problem is, I don't really need it. My regular 18V drill does well enough for repipes and such.
    If I were ever to get back into roughing in new houses a lot, I would probably get it. But then again, my inverter and battery bank on my truck has no problem running my corded SuperHawg.
  5. Mar 1, 2017 #5
    WorkingStiff
    WorkingStiff
    WorkingStiff
    Dec 10, 2016
    9
    I don't really need it either, been fine without it...but damn do I want it :)
Share This Page
