Drain pipe in the garage clogged?
Discussion in 'Drain and Sewer Cleaning' started by MrBlazito, Jun 5, 2014.
  1. Jun 5, 2014 #1
    MrBlazito
    MrBlazito
    MrBlazito
    Jun 5, 2014
    7
    Hello.
    I have a drain pipe sticking out of the wall in the garage that suddenly started pouring out water all over the garage floor when any of the sinks in the house is used. So far I have used a drain snake without any success. I got about 20ft of wire down the pipe but was not able to unclog it. What else can I try?
    Pic of the drain pipe in the wall down in the garage.
    [​IMG]
  2. Jun 5, 2014 #2
    journeyman
    journeyman
    journeyman
    the professional
    Oct 4, 2012
    471
    150
    san diego, california
    That is called a stand pipe for your washing machine. You need to use a powered snake. You might want to try to out a little bend on the end of the cable so it will go down line
  3. Jun 5, 2014 #3
    MrBlazito
    MrBlazito
    MrBlazito
    Jun 5, 2014
    7
    The metal pipe in the wall is what I'm talking about. Is that what you're referring to? When I turn on any sink in the house, water starts to pour out of the pipe in the wall. I went as deep as I could with the snake wire. It came out without any debris on it.
  4. Jun 5, 2014 #4
    MrBlazito
    MrBlazito
    MrBlazito
    Jun 5, 2014
    7
    UPDATE: Went into the garage and the water was pouring out of that pipe pretty heavily. I did not run any sinks or use the restrooms in the last few hours. I'm confused now. Can it be that the drain pipe is shared with my neighbor?
  5. Jun 7, 2014 #5
    journeyman
    journeyman
    journeyman
    the professional
    Oct 4, 2012
    471
    150
    That metal pipe is what i am referring to. Yes it could be attached to nieghbor. Your cable is probably going through to the other unit
  6. Aug 9, 2014 #6
    Matt30
    Matt30
    Matt30
    Professional Professional
    Jan 17, 2012
    1,923
    755
    Halifax, Nova Scotia
    You really go throwing salt down steel drain pipes?
  7. Aug 9, 2014 #7
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    3,868
    930
    Santee,Ca,
    Salt. that's a new one.
    Water seeks it's lowest lever. If the washer drain is the lowest drain in the house, could be a main line stoppage Hand snake has it's limitations. You're gonna need a bigger snake. and maybe even another place of insertion of that snake into the drain. Time to call in the pro with the right equipment to do the job
  8. Aug 12, 2014 #8
    Miles
    Miles
    Miles
    Active Member
    Aug 4, 2014
    41
    , NJ
    If water really pours out heavily then use air compressor to hydro-pneumatically clear the line if you have otherwise take advise from Experts.
  9. Aug 12, 2014 #9
    johnjh2o
    johnjh2o
    johnjh2o
    Senior Member Professional
    Jul 21, 2011
    3,205
    733
    Melbourne, Florida
    That not only won't work but it could be dangerous.
    journeyman likes this.
  10. Aug 13, 2014 #10
    journeyman
    journeyman
    journeyman
    the professional
    Oct 4, 2012
    471
    150
    just get it cleared by a professional it will save the aggravation
  11. Aug 14, 2014 #11
    phishfood
    phishfood
    phishfood
    Well-Known Member Supporting Member
    Jan 18, 2010
    5,683
    965
    Orlando, FL
    I would not recommend anyone try this idea. It sounds like a good way to make a huge mess.
  12. Aug 18, 2014 #12
    Miles
    Miles
    Miles
    Active Member
    Aug 4, 2014
    41
    , NJ
    ohh really then what you will recommend on such situation? I am confused:confused:
  13. Aug 18, 2014 #13
    johnjh2o
    johnjh2o
    johnjh2o
    Jul 21, 2011
    3,205
    733
    Melbourne, Florida
    I for one have never used compressed air to clear a waste line. I can't see how it would work as the compressed air would just go up through the vent before having any effect on the stoppage.
  14. Aug 23, 2014 #14
    Mr_David
    Mr_David
    Mr_David
    Jan 12, 2010
    3,868
    930
    Santee,Ca,
    I have seen the mess it can make. 3 story building. Dumbass on the 3rd floor used a shop vacuum( big heavy duty one) to blow out his clogged kitchen drain. Blew it out the vent. Wasn't a pretty site. Kind of like using a blow bag that connects to a water hose. Than can even make a bigger mess
    phishfood likes this.
Share This Page
