Drain pipe in 4 story residential
Builder-Song
May 22, 2019
California
Been searching for hours now and need answer soon.
Thank you in advance.
My house is built with cast iron piping due to it being 4 story. My question is regarding the bath drain and ptrap,. The pipe underneath is cast iron. Do I have to make the drain portion and ptrap metal as well? Or can I use ABS. Would ABS handle the pressure test with that amount filled with water at the lowest level?
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
3,065
653
Boston, Massachusetts
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
3,065
653
are you just changing an exsisting tub drain or are you testing the stack and its branches??????if your just changing the tub drain check the acceptable materials in your local plumbing code
frodo
Just call me Macgyver
Professional
Supporting Member
Sep 28, 2014
8,557
2,957
A 4 story building?
you can not use plastic in a 4 story building,
The code for the use of ABS/PVC is maximum 3 stories
A 4 story building will require you to install cast iron piping
or copper.
