Drain pan drain - help identify
SteveWPBFL
Jul 1, 2020
Wpb Florida
Hello! I am working on a shower drain that has cracked on the insert piece that screws into the drain. I will attach some pictures. I have checked HD, Lowe’s, Ferguson Supply, Palm Beach Plumbing Supply and Next Plumbing supply and I cannot find this drain anywhere! Nor can I find a similar thread that will work with what I have.
I am trying to replace the insert without having to jackhammer the ceiling enough to replace the entire drain. Any assistance where I can locate a replacement will be appreciated greatly!
thanks, Steve
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,645
502
Boston, Massachusetts
Is the core hole just big enough for the drain pipe,so you can’t pull the remaining parts out
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
2,645
502
Is the core hole just big enough for the drain pipe???????
So the strainer assembly is between the slab and the shower???????
You may need a fiberglass/tub repair guy to cut a small section out
Then, can you cut from below and pull it out?????
I’m guessing you can’t find a manufactures name
A long time ago we have a company cut a hp walk in shower in half to get it thru a door otherwise we would have had to take part of a block wall down
SHEPLMBR
not a Junior Member anymore!
Sponsor
Mar 9, 2016
1,245
371
Augusta WV
Is the piece this threads into molded into the shower?
