drain overflowing
Discussion in 'Drain and Sewer Cleaning' started by misha, Nov 20, 2017.
  1. Nov 20, 2017 #1
    misha
    misha
    misha
    Nov 20, 2017
    I live in an apartment and have a drain on the bathroom floor. When i take a shower (i admit i use a lot of soap), foam comes up from the drain. Is that dirty shower water that's coming up? Or is from somewhere else? Will the problem go away if I stop using as much soap? Thanks
  2. Dec 6, 2017 #2
    HermanAStrong
    HermanAStrong
    HermanAStrong
    Dec 4, 2017
    Hello Misha,
    It may not be due to soap. It may happen also for some other reasons. Better you just try using a small amount of soap for few days and just notice the change. If the problem is still happening better you consult a plumber to recognize the actual problem.
Share This Page
