- Joined
- Sep 28, 2014
- Messages
- 8,578
- Reaction score
- 2,974
3 people trying to tell you to fix it right or dig in that wall later...
View attachment 8184OK, big guy, you go ahead, I apologize for stepping on your toes.
do not know what is on the other side of that wall...you may be able to cut sheet rock in a bedroom or closet. instead of tile.
work it from the other side
Yup I see that as well, and thanks to everyone that has contributed to this post.Vents are connected on the waste side of the p trap as opposed to the fixture side. They typically run up to the attic, connect up there and then up and out through the roof in a much larger pipe. Some vents can and will go up over and down to connect into another pipe using it as a vent. There are also wet vents and automatic air vents. For your purposes, you need to fix what was done incorrectly by opening the wall up and replacing a couple/few tiles. You don't need to tear apart your whole bathroom. A repair like this would typically take about 4 to 6 hours if you have all the parts on hand and voila!
No more flies.
Summer is coming; it will only get worse.
dude,,,,where does the ac drain to?
if it drains some where in the house. there is a ptrap
if the unit is not used, the trap will dry up/evaperate
and the children of the flies could be coming in rat dar
