Drain field questions
Bucky Plumber
Dec 1, 2019
56
8
Wisconsin
A couple of drain field questions for everyone that I can't find solid answers to online...
1. Every once in a while we get a sewage smell from the drain field vent pipe. Is this normal? Some places online indicate that this is an issue while other places state it is normal. I usually only notice the smell on windy days or after heavy water usage (water softener recharge). On other days I go right next to the vent and do not smell anything.
2. Is it normal to see some water in the drain field through the drain field pipe. I opened the upstream drain field pipe, shined a flashlight down through the PVC pipe and saw standing water at the bottom on the pipe. Water was probably ~2 feet under ground level.
Thank you for your opinion.
