Doubling up on Tank Alert alarm
Mike I
Jun 1, 2021
Indiana
I have a SJE Rhombus Tank Alert Series 101 alarm set up on my sewage ejector pit with a high level float switch. I also have a sump pump pit nearby where I'm installing a battery backup system. I'd like to add an alarm alert to the sump pit so I know if/when the line pump has failed and am relying on the battery backup system. I'm wondering if I can just install a second float switch on the alarm, using the same 12V contact on the alarm. I'd have to buy the float switch but it would save me the cost of the alarm base.
JG plumbing
Mar 26, 2021
933
308
Iowa
Are you asking if you can wire two float switches in parallel and have them both trip the same alarm?
Mike I
Jun 1, 2021
Indiana
Exactly- in the event of an alarm I'd have to check the respective pit to tell which one was not pumping down which of course will be apparent as soon as I enter the room. They'll both be high level activated so I figure as you say it's just creating a parallel connection on the terminal block, and the alarm switch will close on either pit rising to high level.
Twowaxhack
Professional
Professional
Feb 9, 2021
2,690
1,069
United states
The only thing I could think of is that you’re mixing the devices between two pits. I’m not sure how your electrical is configured.
It could be potentially dangerous if someone thinks the powers off to the pit but there’s another circuit operating the high water alarm from a different pit.
I’m not saying this applies here but you get the idea.
As far as function it will work fine. In fact I would probably do it for myself but not for a customer.
