Does my toilet drain have too many bends? Picture.
Mousemaster123
Sep 19, 2022
Canada
The ABS is 3 inch connected to a 4 inch cast iron sewer pipe. The drain will be used for a toilet. Will the bends in the 45 degree connectors create a choke point or clogging?
Twowaxhack
Professional
Professional
Feb 9, 2021
9,275
4,089
United states
The problem most likely would be the fernco boots you used will deflect/sag. Then you’ll get blockages in that wye at the bottom.
MicEd69
Supporting Member
Dec 4, 2021
496
135
Missouri
I personally would have used a Long Radius Combo and put one 45 in the horizontal line kicking it to the right in your picture so it would line up with the Combo Tee-Wye.
You might consider digging out more under the ABS and more upstream and downstream under the cast iron and place some concrete up to the belly of the pipe to somewhat ease Twowaxkack's concern of the wye settling away from the cast iron.
MrInfoPhilly
Professional
Professional
Jan 15, 2022
124
27
Earth
You've couldve rolled the sweep on a 45 to make a straight shot down instead of an extra offset.
