Do some/all plumbers have tools to solve this problem?
Discussion in 'General Plumbing Help' started by zzmac, Sep 12, 2018.
  1. Sep 12, 2018 #1
    zzmac
    zzmac
    zzmac
    Mar 30, 2017
    13
    I need a plumber to fix my car! lol
    I broke the head off a bolt on the radiator in my sports car. The bolt is at the bottom of the rad and is used for draining coolant. To make a long story short the 1" threaded part of the bolt rolled into the radiator.
    The bottom outlet on the rad (where the rad hose connects) is approx. 8" long then it makes maybe a 6" turn into the rad.
    Do plumbers have a flexible tool with a camera that could go in the outlet, see where the bolt end is and then put in a flexible tool that could grab it and take it out?
    I tried flushing and vacuuming it out and it didn't work. I'm sure it's sitting in the rad just below where it meets the outlet.
  2. Sep 12, 2018 #2
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,720
    2,126
    pull the radiator, and turn it so that the piece falls out of the hole where the bottom hose connects
    that info is billed under fixing cars , you owe me $47.63
    If i draw picture of a stick man shaking the radiator, that is another $50.00 you need a picture?
  3. Sep 12, 2018 #3
    zzmac
    zzmac
    zzmac
    Mar 30, 2017
    13
    Major pain in the ass to get the rad out. Do plumbers have these type of tools?
  4. Sep 12, 2018 #4
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,720
    2,126
  5. Sep 12, 2018 #5
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,720
    2,126
    automotive store has a flex thing with a grabber on the end, for picking up dropped screws
    and you can find mini camaras at? online
  6. Sep 12, 2018 #6
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,720
    2,126
    automotive store, parts grabber,
    havasu likes this.
  7. Sep 12, 2018 #7
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,176
    1,262
    Southern California,
    Harbor freight has little cameras and pincher pick up rods that they sell pretty cheap.
  8. Sep 12, 2018 #8
    anticlmatic
    anticlmatic
    anticlmatic
    Active Member
    Jul 24, 2018
    44
    12
    Michigan
    I wouldn’t bother with the cameras. I’ve used them, and if on the off chance you can make sense of Wtf you’re looking at you’re still going to have no idea where it’s oriented if it’s out of sight. Tie a magnet to a stick and go fishing.
  9. Sep 13, 2018 #9
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    839
    165
    North reading, Mass.
    anticlmatic likes this.
  10. Sep 13, 2018 #10
    chiraldude
    chiraldude
    chiraldude
    Hardcore DYI-er
    Nov 16, 2013
    104
    24
    Southern Minnesota
    Search for inspection camera on Ebay. Lots of items less than $30. I got one and use it mostly to see where pipes and wires are going in wall cavities. Not sure you will be able to find one that can fit in the tiny space inside your radiator though.
    DIY work on cars can be a real pain. Pros have the advantage of having "been there done that" knowledge so they don't drop parts down holes nearly so often.
  11. Sep 13, 2018 #11
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    152
    20
    Northwest Washington
    Just leave it in there. Water flow in the radiator is upward, and it's too big a part to jam any of the small tubes. If it's a brass bolt (what make/model?) a magnetic grabber wouldn't work anyway. Over time, it may bounce around enough to cause a leak, then you'll have justification to pull (and replace, probably) the radiator.
    Diehard likes this.
  12. Sep 13, 2018 #12
    Richard Gavle
    Richard Gavle
    Richard Gavle
    Jun 4, 2018
    48
    10
    A car radiator generally has what is known as a "Drain Petcock" the part you turn to drain universally turns inward (clockwise) to drain and if you try to remove it by loosening it you will indeed break it off as it is captive at radiator side. The good news is that the entire petcock assembly almost always is screwed into the tank of the radiator and can be removed as a unit and replaced cheaply. Look for a 6 sided nut usually around 13 or 14 mm if metric or 1/2 or 9/16ths if standard thread.
    I was one of dem sertifiid master teknisians and can not tell you the number of times I have seen broken petcocks.
  13. Sep 14, 2018 #13
    Matt30
    Matt30
    Matt30
    Professional Professional
    Jan 17, 2012
    2,035
    794
    Halifax, Nova Scotia
    What about a wet vac? Try and suck it out?
  14. Sep 14, 2018 #14
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,176
    1,262
    What is it....4 bolts, two hose clamps....pull it out, turn over, shake like crazy, then once it is out, reinstall?
  15. Sep 14, 2018 #15
    Matt30
    Matt30
    Matt30
    Jan 17, 2012
    2,035
    794
    Im sure on older cars it’s that easy. Taking anything apart on newer vehicles sucks.
    Just to change the headlight bulb on my car I had to take off my front grill and remove the entire headlight just to access the bulb
    :pissed:
  16. Sep 14, 2018 #16
    Richard Gavle
    Richard Gavle
    Richard Gavle
    Jun 4, 2018
    48
    10
    Had an Toyota Avalon and got an inspection ticket for the 3rd (center) brakelight being out. Part printed led and board was 175 and the labor was 4 hrs which worked out to 875 dollars to have it done in a shop.
    Had to pull the rear sidepanels, rear airbags, back seat, and a bunch of other stuff to remove the housing all in my driveway in December lols
  17. Sep 14, 2018 #17
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,176
    1,262
    Yikes!
  18. Sep 14, 2018 #18
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    152
    20
    Wait until you have to replace a halogen headlight bulb in a Prius. Or change the spark plugs - for them, the first task in the manual is "remove windshield wipers".
  19. Sep 14, 2018 #19
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    152
    20
    deleted.
Share This Page
