Disposal only draining when turned on
efnx
Oct 15, 2021
NY
Recently replaced sink and garbage disposal that is only draining when turned on. The garbage disposal is brand new so no food / clogs there, and I’ve disassembled the P trap drain assembly twice, which is all clean. After a brief period of running water, it will start to pool in the sink and will only drain when the unit is turned on.
The disposal output is a few inches higher than the main drain as it should be, so hopefully no issues there. This is also in an island with a vent loop as pictured. Pulling my hair out with this one, any ideas / advice would be GREATLY appreciated.
efnx
Oct 15, 2021
NY
Should be vented via the vent loop stack behind, like this
arctic bill
Dec 24, 2020
302
107
montreal
most people put things down a garburator that should not go
  • Coffee Grounds. This is one of the biggest no-no's when it comes to a garbage disposal or any drainage system. ...
  • Grease. ...
  • Eggshells in Disposal. ...
  • Onion Skins. ...
  • Potato Peels in a Garbage Disposal. ...
  • Hard Foods. ...
  • Dry Expandable Foods.
  • any thing fibrous, like top of bananas
  • stuff from the garden , leaves, twigs , stalks ,
BlueSkyHigh
Supporting Member
Jun 17, 2021
176
70
Northern Virginia, USA
I know my water authority, if they could, would ban all ISE's, etc. from the face of the earth (at least in our county) for obvious reasons but what's so insidious about coffee grounds?
arctic bill
Dec 24, 2020
302
107
montreal
I was a plumbing inspector , and i did ban all garburators. the municipality also passed a composting garbage pick up to recycle all that stuff that went down the drain. I always hated thanksgiving blocked garburator calls. coffee grounds are excellent in a garden
skeezix
Aug 24, 2019
116
28
Colorado
I learned the hard way 40 years ago... the only thing that goes into my garbage disposal is whatever gets through the fine-mesh strainer on top of it.
Twowaxhack
Professional
Professional
Feb 9, 2021
4,925
2,211
United states
As a test I ran 15 pounds of crawfish down my 3/4 ISE garbage disposal.
No problem, it’s 2” pvc with a 2” pvc ptrap then dumps into 3” pvc above a toilet. The 2” is only 3’ long, so it’s a short run.
Good plumbing design makes all the difference.
Ohio Dave
Aug 5, 2020
Cleveland, Ohio
  • Grease. ...
  • Onion Skins. ...
  • Hard Foods. ...
I have a friend whose elderly father was disappointed that his garbage disposal broke after he fed it chicken bones.
