Thank you Jeff much appreciated. - RobertMany questions un-answered, others vaguely.
But there is no proper way to tap the pipe in the middle of a run.
Not in a pipe always under pressure.
If you are adding copper to galvanized, I have always used a brass transition piece.
A valve, coupling, nipple, etc.
To reduce corrosion from galvanic action.
Using teflon tape also might help slightly with that, as some think, but not really a factor.
Hi Doc, The hot pipe closest to to drain on left is supply coming from crawl space under house. Feeds up to sink above. The sink and surrounding tile are 1930's vintage so irreplaceable. I was trying to avoid having to demo the kitchen sink. I think i have a solution as to feed 2 separate copper pipes (in-line) up to sink and connect half way with hot valve in center. That way i don't have to demo the outside wall as one contractor suggested. Jeff advised me to use brass at thread connects from source galvanized pipe. Space is tight in this old construction. Cabinets were the last thing added in those days.Can you take a picture of the supply lines that supply the sink faucet? That alone would answer a number of questions.
I would never use a Dresser coupling for a line under constant pressure.
Legal or not.
I used one exactly one time, to repair a rotted galvanized shower riser with terrible access from the back side, where I could not safely unscrew the upper pipe from the shower arm ell.
There is only pressure during a shower, of course.
And the ends of the pipe were restrained, so they could not push apart.
But it is similar to a Sharkbite connection, but so much iffier.
I had a house with that same style of coupling on pvc sump pump discharge lines, and had several floods when they failed to hold.
