Dirt over riser lids, other riser questions
Discussion in 'Septic Tanks' started by FliesLikeABrick, Sep 24, 2018.
  1. Sep 24, 2018 #1
    FliesLikeABrick
    FliesLikeABrick
    FliesLikeABrick
    Sep 24, 2018
    Northern Virginia
    Hello all,
    Our septic tank riser comes just to the surface of our lawn, such that with a bit of regrading to raise the lawn surface -- we could trivially put a few inches of top soil and plant grass over the top of the riser lid.
    Is this a particularly good or bad idea? It would actually reduce the probability of water getting into the riser, by encouraging more drainage away. We could of course also put a bit of a gasket under the lid to seal it against the riser, though I think that shouldn't be needed in our specific situation.
    We don't mind digging the few inches to expose the lid for regular inspections and pumping, since it is way better than digging 3-4 feet to the actual tank surface.
    From searching online I was not able to find good answers to this -- most searches returned general results about using risers to avoid burying your tank access, etc. However, I am specifically asking about covering the riser lid.
  2. Sep 25, 2018 #2
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    252
    67
    83467
    They are frequently buried. And, we frequently have a hard time finding them, particularly if they have a plastic lid, and don’t set off my locator wand. If you do bury it leave a picture somewhere showing the location, and distance to it from a couple of distinct places on the house.
    I spent half a day looking for one that had been covered in dirt, and then had a patio built over it. The patio was in pictures of the house which were fourteen years old, so it took a while to fill the tank with solids.
  3. Sep 25, 2018 #3
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    219
    33
    Northwest Washington
    I purposely set mine at grade, to make them easy to find. If you're really trying to pretend you don't have a septic tank, put very leafy potted plants on them.
  4. Sep 25, 2018 #4
    FliesLikeABrick
    FliesLikeABrick
    FliesLikeABrick
    Sep 24, 2018
    Northern Virginia
    The goal is less to hide them from view, and more to grade over them to further encourage surface runoff away from this area. Right now our riser comes up slightly below grade around it, encouraging surface water runoff into the riser and septic tank.
    The alternative is to dig down to our tank and replace the riser with a taller one, but I am hoping to first try and remove this depression from our yard where the area has settled (which includes covering the riser lid)
  5. Sep 25, 2018 #5
    Jamesplumbing06
    Jamesplumbing06
    Jamesplumbing06
    Feb 24, 2016
    556
    111
    you can buy an extension to set on top of what you have. But having the lid under dirt will be likely to let water in also. We use 18” culvert pipe for risers. Tell the pipe yard you want the female end measured and cut. A lawnmower wheel will go thru plastic lid. Eventually
Share This Page
