Designing Blackwater Tank for Service
Damron
Mar 22, 2020
9
Kentucky
I own a tiny one room cabin with a tiny bathroom. Due to the cost of creating a septic system in the rocky terrain and the limited use the cabin will receive, I'm going to use a black water tank like you might find on a construction site or RV.
The function of the toilet and tank are simple, it's a straight toilet to tank.
With the thought that I'm going to have a septic service company pump it out every 6-12 months, I'm wondering what fittings and ports a septic guy would like to see.
If my tank had a normal dump port with valve and sewer hose could the pump keep up with the drainage?
As there is little clearance to pump from the top of the tank, I'm looking for options that a septic guy would be okay with.
I've never seen the pumpers use and fittings at the end of their hose. I'd be willing to buy one.
Ideas?
bbp
Aug 19, 2018
79
15
Wisconsin
Look up septic holding tanks. Most holding tanks are septic tanks that have not had the knockouts removed.
Damron
Mar 22, 2020
9
Kentucky
The issue is that most tanks are pumped from the top with a large access port.
Damron
Mar 22, 2020
9
Kentucky
I'll try again, so far nobody has understood the issue I'm having or the question I'm asking. I've engineered the toilet and tank. I have no questions about what tanks are available. My question is aimed at a septic technician.
Septic tanks are normally pumped from above.
My tank will not have access from above.
There is no problem installing a port on the side.
The question is, can septic tank pumpers deal with this?
1) They are not used to attaching any hardware to the end of their pump hose.
2) If I stuck my drain hose inside their pump hose, can they deal with the flow when there is no fitting between their hose and mine?
Mitchell-DIY-Guy
Oct 16, 2019
151
48
North Carolina
Assuming you won't be totally off the grid...have you considered one of those "electric toilets"?
If you have power, you won't be counting flushes or waiting for the "Johnny On The Spot" pump guy to show up...
Mitchell-DIY-Guy
Oct 16, 2019
151
48
North Carolina
My suggestion is to call the septic pumpers serving your cabin area. You are correct, they normally deal with top entry buried tanks. They hold 1,000 gallons +/-. I know it cost me $175 to pump recently; so if you are not using a septic tank, but pumping EVERYTHING that's a pretty costly setup.
Damron
Mar 22, 2020
9
Kentucky
I have lived on boats and RV's, I've considered all solutions. Having my tank pumped once or twice a year is better than any of the alternatives.
My preference is to place the tank under the cabin like and RV. I don't want to use a macerater and full flush required to get stuff to a tank not directly under the toilet.
Damron
Mar 22, 2020
9
Kentucky
$175 every 6-12 months is nothing. I'm not running gray water to the tank.
Jeff Handy
Jul 5, 2019
1,671
289
Chicago suburbs
I was also thinking of the Incinolet toilet that Mitchel mentioned.
There are also composting toilets.
Damron
Mar 22, 2020
9
Kentucky
I'll contact local companies. Expected to find a service guy in the forum.
Jeff Handy
Jul 5, 2019
1,671
289
Chicago suburbs
If your cabin is remote, or has difficult access, you might pay a higher fee to get a pumper to come out there.
Damron
Mar 22, 2020
9
Kentucky
Composting toilets are horrible. I prefer my crap to exit the bathroom. With a four inch pipe straight down, very little water is used.
I've purchased a full size RV toilet with two position foot lever, fill and flush.
Damron
Mar 22, 2020
9
Kentucky
It might be necessary for tank to extend from beyond back of cabin to allow access from a port on top of tank. I was hoping for a cleaner looking install.
Diehard
Aug 19, 2017
2,640
469
North Reading, Mass.
Why wouldn't you just contact your local septic company first.
Find out what type and size connection he would require to be able to connect to.
And that's it.
Why take a chance based on someones advice over the internet?
