fschlenter911
Hello, I have a Cast Iron sewer line under the street to the sewer main. Is it good to have it descaled or does it weaken the pipe? Thx
Hi Jeff, I had my sewer replaced from the house to the street. So maybe I am good on the sewer settling issue. Will cross my fingers there. Having said, I have a cast iron vertical in the home bending under the slab and going to the front of the home. Interestingly, I also have cast iron going from my walk-out (in back) to a connection point under the slab I presume. Then I have the replaced sewer line (pvc) from the front of the home to the street. Connecting to a cast iron lateral under and across the street to the county main sewer line. That would be to the best of my knowledge configuration. Thanks to you and everyone on this thread for being so helpful!!You did not mention any pvc sewer in your original post.
A common cause of sewer failure is when the house gradually settles, and the cast iron sewer breaks, usually very close to the foundation.
I've seen clean-outs stubbed in at the back when that was closest to most of the served vertical lines. Easier than running the snake from the front uphill the length of the house.The sewer line going out to the back yard might be going to a storm sewer.
Or just to a dry well, or to daylight.
