I had a slight drip on an old delta single handle kitchen faucet. I replaced the seats and springs for hot and cold. After reassembly it drips unless I fiddle with the handle to find the sweet spot, and then there is no leak. If I pull the handle forward beyond the no leak sweet spot, there is a steady stream of water. It did not use to do this. Also, if I remove the handle and pull the ball stem forward to the center notch of the locking disc, it doesn't leak and won't go any further forward than the visible end point. Did I do something wrong in reassembly? I have done this many times in the past without issue.
