That wall should be 2x6, not 2x4.
Hi Jeff, I wouldn't expect so. That's an interior wall I believe. The 2x6 spec is exterior walls.@Jeff Handy hit the nail on the head. Why is that a 2x4 wall if 3" has to run through it? It should Def be a 2x6 wall.
builders just don't do that anymore. They would rather pad the wallThat wall should be 2x6, not 2x4.
Not required here, but a 6" "plumbing wall" is definitely an asset where drains are run, along with the metal covers over pipe.
And, did you know: a common stud finder will interpret a pex water line close to the drywall as a stud? [please don't ask how I know]
Architects F’up all the time and draw things that can’t be built. The trades often have to work together to correct their F’ups and make compromises....why?
because that is what the architect specified, the builder wants to pay for, and the plumber has to live with. I see this kind of stuff all the time. In this particular case you were looking at a situation regarding a plumbing stack. I see similar things with HVAC ducting or equipment, and or electrical systems.
“ you are the [insert the name of trades] that’s why we pay you; you figure it out“
