What can I do to fix a leaky tapered union? (copper or brass) On dielectrics I know I can use a new washer...
UPDATE: Bigger Wrenches seems to have worked! (_way_ more that 50ftlbs)
Here are things I tried:
1: lap with toothpaste? (spun) didn't help
2: evaluate mating surface with bluing or marker? (very little rubbed off)
3:tighten righteously? (tried, but heard I shouldn't have to)
4:tap wiggle to ensure alignment (tried)
5: search youtube I'm at wits end, and youtube only shows some guy using shark bite couplings, and the internet searches only have people doing goofy things with teflon tape.
6: Replace union (only replaced once, the second one was much better, but still leaks about a drip every 5 minutes)
Things I have not tried:
teflon tape (seems wrong)
pipe dope (seems wrong)
annealing the copper (perhaps I overheated the fitting and cooled it quickly?) ( would I have to disassemble a bunch of stuff? and then deal with resoldering fittings? )
I confirmed that my solder joints are not the leak.. But I may have changed the copper properties in error.
7. (What worked) Bigger Wrenches! I bought 2 15in adjustable wrenches that could get the 1.5in nut (rather than my pipe wrenches that were marking the nut) It was in an awkward position, but I still had enough space, I didn't quite go to the point where I was scared, but it was much tighter than I expected to go.
more details:
I switched from a propane torch to map and a bernzomatic 8000.
My use is to attach a heat exchanger in a closed loop system. the heat exchanger has 4 male 3/4in threaded attachment points all facing the same direction. I plan to use flexible copper for most connections, but the connection from the circulation pump will be rigid.
Babbling story below, I'm sad about unions.
I installed 2 used 3/4in copper unions just fine.. they were older. (someone else soldered it)
I thought I could install a new half inch one just fine... Maybe I heated it up too mich and cooled it too quickly?
I was shocked by how hard I had to tighten it to stop it from leaking.
I had some new 3/4 unions and got some solder on the mating face.. I took it off and put on another one.
When I attached it, it leaked like a sieve.. I am sure I had it in line because the other side was not locked down yet.. I was going to fasten it based on the union alignment... I jiggled it, I wiggled it, (I couldn't beat it because the heat exchanger seems fragile).
I then tried to see where it was touching by using sharpie and seeing if anything rubbed off. only a tiny bit rubbed off.
I then tried using toothpaste to lap it, but nothing touched.
I found a union with female threads on one side... that seemed better than trying to align a pipe.. The wrench faces/(nut) are larger, so it had trade-offs I got it installed... and... there is a drip every 2 minutes or so, so it's not good.
I did make a mistake with a dielectric union by leaving it in water (for a short time) (thought I was getting flux off) and it rusted and leaked, but put a new one on and it was fine...
more details:
