Copper Pipe in my house 1/2" OD and 5/8" OD
Discussion in 'General Plumbing Help' started by tom12l, May 8, 2011.
  1. May 8, 2011 #1
    tom12l
    tom12l
    tom12l
    May 8, 2011
    I am trying to fix some pipes in my cabin that froze this winter.
    I need to replace some compression fittings. I tried to put a 5/8 inch OD compression fitting on the line. It was a little bit loose but I could not tighten it down.
    Is it possible I have 1/2 inch OD pipes?
    Where would I locate 1/2 inch OD to 5/8 inch OD reducers?
  2. May 9, 2011 #2
    Caduceus
    Caduceus
    Caduceus
    Professional Professional
    Apr 3, 2011
    1,288
    351
    Pittsburgh, PA
    If you are talking about copper you may need to try a plumbing/hvac supply house for reducers or compression fittings. It would be best to take a piece of the pipe to the supply house to save you some trips and returning materials that don't work. I recently met a customer who bought all 1/2" od compression fitting at his local hardware store. Problem was he needed 5/8" od. Small hardware stores can also be a great resource for finding fittings.
  3. May 9, 2011 #3
    SlowDrip
    SlowDrip
    SlowDrip
    Plumbing Sales Professional
    Nov 15, 2010
    395
    Oshawa, Ontario
    It is possible that they have run 3/8" copper for some reason (which would be 1/2" OD). My local Lowes has 3/8" sweat fittings and 1/2" compression fittings but I don;t know if yours will.
Share This Page
