cmac2012
- Joined
- Mar 20, 2018
- Messages
- 87
- Reaction score
- 4
A nice young single father guy, cute modest house, I've done a number of small remodel jobs for him over the years, calls me telling me the hot water pressure in the kitchen sink and bath are really bad. Bathroom sink is strong though.
Kitchen faucet aerator is passing cold water just fine. He said the pressure drop off was sudden. I took the valve out, there was an oval piece of scale that was made for the opening, jammed in good but it disintegrated soon enough. Pressure was back in gangbusters fashion, dude was way happy. Bath valve is clean as a whistle however.
I went into the crawl space, all galvy except about the last 15 or 20 feet of the line going to the kitchen hot water. The kitchen cold had an approx 2 - 3 foot segment of copper going from just under the sub floor up to the faucet.
I was surprised that there wasn't more visible corrosion at the joining point on the hot water leg.
My instincts tell me I should replace this with a di-electric union. No idea if the piece of scale I removed is from an active scale farm just inside that joint. When I've seen similar in the past there was large sign of corrosion. The remodel (pre-flip) on this house was done 5 - 6 years ago. I'm surprised this looks fairly clean, others I've seen had large amounts of green funk.. Doesn't seem as though a bunch of teflon tape would prevent it, though it looks as though a lot was used.
I suspect a similarly bad joint is in place on the cold water side. Was a bit muddy so I didn't crawl over to see.
The bath hot water line is galvy all the way. It goes under the sink with a T then ends at the tub. I suspect more makes it to the tub than to the sink. The tub has a tile surround, but the bath valve has a closet between it and the hallway. Will make it easy to get in if we decide to add a run of copper. Wouldn't be much more work to do it upstream of the bath sink, get both that way.
I'm guessing that the tub valve might have a slug of scale right at the point where it joins the valve. But if we're going to open the wall in the closet, may as well give it the full treatment. Maybe a new valve as well.
