freecrowder
I'm going to convert my well to city water because of DEQ. I need to know anything I might not be thinking of. We are going to cut the line coming into the house and connect to city. The end going back to the well will be capped and the well used for irrigation. A few things, the pressure tank will still be plumbed to the city side now. Does it have to be removed? Will the in ground water system work without causing well pump problems if I just turn on the pump when i'm watering and off when the valves shutoff? Will the pressure from city be ok with existing plumbing?
