Connecting mini split condensation drain to main. Vent or no?
JohnSizzle
Dec 19, 2021
can
Hi all,
Looking for wisdom regarding configuration before I drywall. Is there any watch outs with this setup? Should I tee in a vent at beginning of line? House is 8 years old in Canada. Thanks in advance!2021-12-18 16.37.47.jpg
If that's just a vent you could tee into it along with a ptrap I would at the very least, if your going nna sheet rock over it put an access panel so you have access should also not
Sheet rock over that wye, that's access to you
Main drain if you need to snake
It’s needs a ptrap to indirectly drain in to, a floor drain would work. Or run it outside.
It needs to be accessible outside the wall.
