Hello ,
I am trying to replace the toilet shut off valve and could not remove one part. (picture attached)
I have no idea about this and have't seen at any stores . Did any of you know this kind of part ?
How to replace this part ? Where to buy this part ?
Like Matt & CT said that is a push type fitting. Hold onto the brass fitting and pull back on the black piece. It will come off. If its
copper underneath the fitting I would put on a 5/8" X 3/8" compression angle valve. You can find this valve in any store or
plg supply house. Let us know how it turned out for you.
Thank you for all the help . It's a push connect type fitting . (pro - called shark bite fitting)
The procedure to replace the fitting was exactly same as the one mentioned in the post reply .
I did end up in calling the pro to replace it . The copper pipe diameter is little bit smaller than the standard fitting .
The pro Sweat the Copper Pipe with compression fitting and connected to the shut of value .
