Through out my while house the cold water pressure is significantly lower than the hot water pressure. I was wondering what could cause this and how to fix it. I am on city water. Thanks
Since most home hot water is via the water heater, I don't see how this can be. The cold water feeds the tank and the pressures are normally the same, or the hot water a bit less than the cold. Do you have a pump of some sort on the hot water line(s)?
