Code check, Rough in of kitchen basement sink
Ryan S Persitza
Nov 6, 2018
Wisconsin
I have > 135 degrees of turn is an additional cleanout required? I will be using a fully shielded cupling. Located in Waukesha County, Wisconsin
pGRWumr
consider a backwater valve as well...if street backs up youll have a mess
  • Protects basements and other low level areas from the backflow of sanitary sewer, storm sewer, or septic system
  • Easily fits and this is easy to install
  • Made in United States
  • Protection against the backflow of sewage and storm water
  • Compact, lightweight and easy to install
  • All canplas backwater valves are socket x socket with all sockets being dwv
  • Acme Threads provide positive traction and extra strength
Compare with similar items
New (5) from $22.40 + $8.10 shipping
eet backs up youll have a mess in basement.
Don’t you dare put a check on drain just another obstruction waiting to cost you and then the snake tears it up. No do t do that. You pictures have pressure fittings. Don’t do that. Need dwv fittings. Clean out will be trap and studor vent you install for sink. But long as you have smooth turns you can corkscrew a drain just no pressure fittings
Good eye. Never even noticed they were pressure fittings.
around here any plumbing in basement lower than youre lateral is required to have backwater valve. i agree they can clog but have you ever seen city drain back up into a basement...its not pretty. like a fire hydrant spewing raw sewage.
