Quantcast
Cleanly remove hose ring
Bcyes
Active Member
Oct 25, 2019
32
WA
What kind of tool can be used to Un-clamp these crimp rings Without cutting the hose / fittings?
Tried using Dremel on previous job but my hands were not steady enough and accidently damaged the hose.
Bcyes
Active Member
Oct 25, 2019
32
WA
the pex is very short. might not have enough left for a new fitting to put on after cut. also would like to replace this very old short section of pex.
Cutting it there might damage the shut off valve? as they are too close
SHEPLMBR
not a Junior Member anymore!
Sponsor
Mar 9, 2016
1,029
232
Augusta WV
Use shark bite fittings to replace and a new piece of pipe.
CT18
professional
Professional
Apr 30, 2014
732
219
Bloomfield Hills, Michigan
Fire up the heat gun or torch and rip that pex out of there and the rings will fall off. Then just put a new piece of pex on and crimp it.
Bcyes
Active Member
Oct 25, 2019
32
WA
great idea. that should work. Thanks guys!
Matt30
Professional
Professional
Jan 16, 2012
2,267
879
Halifax, Nova Scotia
That looks to me to be Polybutylene, not Pex. Double check with the rest of your piping before you destroy it, you may need more fittings
SHEPLMBR
Sponsor
Mar 9, 2016
1,029
232
Augusta WV
They make sharkbites to go from Polybutylene to CTS
Bcyes
Active Member
Oct 25, 2019
32
WA
ok checked. pipe is CTS. Will CTS pipe become soft like pex when heat up, so that can be removed without cutting the crimp ring that most likely damage the shut off valve?
would assume the valve is crimp type similar as below. is it true the only way for new connection is to crimp PEX to this valve? any suggestions?
Matt30
Professional
Professional
Jan 16, 2012
2,267
879
As I suspected.
Polybutylene and pex are not interchangeable. You will not find polybutylene tubing to replace it, you will have to transition from polybutylene to pex via a transition coupling.
Jeff Handy
Jul 5, 2019
2,750
606
Chicago suburbs
Post a much wider view of that whole area.
Maybe you can do a much wider repair, and attach onto better locations, not just work in that small section.
Don’t cheap out or be afraid of replacing a few fittings or valves, it beats dealing with a massive flood.
Bcyes
Active Member
Oct 25, 2019
32
WA
Try to avoid changing anything when there has been no problem.
not sure if I can attach new PEX to this valve, crimp?
removing the existing crimp ring still in question
