Changing Flange
Discussion in 'Toilets and Sinks' started by RPOK47, Sep 11, 2017.
  1. Sep 11, 2017 #1
    RPOK47
    RPOK47
    RPOK47
    Sep 10, 2017
    Any opinions on whether or not the toilet flange should always be changed when replacing a toilet?
  2. Sep 12, 2017 #2
    specgrade
    specgrade
    specgrade
    Mar 18, 2010
    21
    5
    Unless the flange is broken, leave it alone.
    phishfood likes this.
  3. Sep 13, 2017 #3
    phishfood
    phishfood
    phishfood
    Well-Known Member Supporting Member
    Jan 18, 2010
    5,683
    967
    Orlando, FL
    I take it on a case by case basis, but to make a blanket rule that a flange needs to be changed every time you pull a toilet, no.
  4. Sep 14, 2017 #4
    frodo
    frodo
    frodo
    Just call me Macgyver Professional
    Sep 28, 2014
    6,036
    1,870
    I only change the flange if it is broken,
    why would do otherwise?
  5. Feb 13, 2018 #5
    3DPlumbingProducts
    3DPlumbingProducts
    3DPlumbingProducts
    Feb 13, 2018
    If its broken, try a quick and easy fix. Its a toilet flange repair kit from 3D Plumbing Products and works on cast iron, PVC or ABS flanges and on 3" or 4" flanges. Its the perfect fix. http://www.3dplumbingproducts.com
Share This Page
