WiiGame
Active Member
I got mad about this one and probably got myself into trouble. (I knew I should have posted here before trying anything, but noooOOOOoooo....)
I'm replacing the tub spout (?obviously?). The black plastic rod/tube inside the old spout -- which screws onto the pictured adapter -- just won't come out of the old and very corroded (prob. 25yr old) spout.
And when shopping for a replacement spout, there are no assurances that the internals of said replacement spout will match in length and diameter and threading to correctly mate with this. In fact, the whole shopping process drove me to think that I had very little shot at success that way. At least with this ~2.5" nipple.
So, the sure thing seemed to be to change to a simple slip-on, and with that part en-route, I thought I could easily remove this adapter.
I got this set screw to move a few turns and to rise up somewhat -- with very much resistance -- until it stopped moving entirely due to now being stripped. And, no, the adapter won't come off in the current state ... though it does have play ~1/8" (each way) left & right, and less play forward & back. So it doesn't appear to be soldered on.
It order to get this set screw to move more -- mostly based on YouTube ideas and then existing forum-based advice -- I've tried:
- WD-40
- tapping a Torx-10 bit into it and trying to unscrew it
- Dremel-grinding a flat-head screwdriver notch into the screw (apparently my bit is too thick to pull that off)
- Dremel-grinding the whole adapter off (scary!)
- propane-heating the adapter and trying to channel-wrench squeeze it into an egg shape that can slip off? so far, the adapter doesn't appear to respond to this and something here is giving off fumes
Thanks! -- WG
