G Gage Lamar New Member Joined Mar 27, 2019 Messages 3 Reaction score 0 Location Yadkinville nc Mar 27, 2019 #1 Can't afford new water heater
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,976 Location right here right now, over there later on. Mar 27, 2019 #2 ONLY IF YOU WANNA DIE!!!
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,976 Location right here right now, over there later on. Mar 27, 2019 #3 temp fix, find the hole drive a piece of wood in it till........................
G Gage Lamar New Member Joined Mar 27, 2019 Messages 3 Reaction score 0 Location Yadkinville nc Mar 27, 2019 #4 What if I hook drain to hot outlet of tank to the drain then open drain and circulate water in tank for a while then flush the tank a few times
V voletl Well-Known Member Joined Dec 17, 2014 Messages 800 Reaction score 250 Location New York Mar 28, 2019 #5 Never seen someone so deadset on poisoning themself
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,976 Location right here right now, over there later on. Mar 28, 2019 #6 I said what I had to say, The rest is all you
C chiraldude Hardcore DYI-er Joined Nov 16, 2013 Messages 126 Reaction score 27 Location Southern Minnesota Mar 28, 2019 #7 If the tank is leaking it won't be long till it turns into a flood! There is no way to fix a leak in a hot water heater. You should make sure it is the tank and not a fitting on top. How much could you afford? Here is an electric water heater for $190. https://www.menards.com/main/plumbi...640-c-8690.htm?tid=9159118495454750442&ipos=1 You don't have Menards in NC so you would have to pay shipping. Home Depot has this one for $320 https://www.homedepot.com/p/Rheem-P...ric-Tank-Water-Heater-XE40M06ST45U1/205810725 Add at least $50 for plumbing fittings. You will have to pickup and install yourself or find someone willing to help you.
