B3EddieB
I am looking to update cruddy shower/tub hardware with something more modern.
The existing fixture is a Moen with the cheap plastic knob, contractor installed in the mid-80’s when the house was built. It has a push/pull type diverter below the mixing valve. It seems that all of the newer fixtures have the diverter in the tub spout rather than in the mixing valve itself. I am trying to avoid having to replace the mixing valve since it works fine as it is and it is very difficult to access through the opening in the shower wall. I have exhausted my search for a decent quality replacement handle and escutcheon that has a provision for the diverter, so my question is this:
Is it possible to disable the diverter by simply removing the valve from its housing and then cap it off, perhaps with a screw-in plug, and then install a new handle compatible with the mixing valve and then install a new spout with its own diverter? I can’t see the part number on the mixing valve but I have attached a photo.
Thanks for any advice you can offer.
