Broken Kitchen Sink - advice?
bshartsis
May 24, 2020
Manhattan
I was hoping someone might point me in the right direction to get started fixing something - as pictured, the pipe under my kitchen sink has worn down and is broken and crumbling, leaking water when the sink drains.
I assume I need to replace this. How difficult is this to do for someone with little experience, are there any special tools, and what part do I get to replace this (or how do go about identifying what part I need to get)? Any advice would be appreciated.
Pat the Plumber CIL
Professional
Professional
Apr 23, 2020
62
37
Springfield , Il
What does it attach to just above the picture . Cut 1.5 inch galvanized with sawzall . Use a 1,1/2" X1,1/4" fernco adaptor to connect a new tubular plastic p-trap which can be purchased at any hardware / big box store . Not rocket science but experience helps .
Helper Dave
Oct 11, 2019
47
12
Wisconsin
Post a picture of the connection just under the sink. Why's it come down at such an angle like that?
Pat the Plumber CIL
Professional
Professional
Apr 23, 2020
62
37
Springfield , Il
Why cut? Wouldn't it be easier if he unscrewed everything?
Would probably need to heat the joints, but much more do-able for novice.
If you think you can get a pipe wrench in there to screw things apart knock your self out . Cut that crap out and move on with life . My small 12 volt Milwaukee sawzall would make quick work of that . Galvanized corrodes together over time , 1/2 " or 3/4 " is one thing . 1,1/2" or 2" is another story
Jeff Handy
Jul 5, 2019
1,797
319
Chicago suburbs
It looks like all you have to replace is that unusual 45 degree elbow that is falling apart.
All the connections look like slip joints, which should unscrew with channel lock pliers.
Yes, a wider angle view or several, showing all the drain plumbing, might explain why you have that weird elbow there.
bshartsis
May 24, 2020
Manhattan
Thanks, everyone, I was able to get a replacement installed without too much trouble!
