Brass Fitting Issue
mred
Jan 27, 2010
I have a brass fitting that I am trying to clean to accept a female screw on fitting. I have heating the brass fitting and wiped off all the solder I could, but there is still a lot there which prevents me from threading on the female fitting.
Any suggestions? I have tried steel wool, emory cloth, and a brass brush....sheez.
thanks
speedbump
Retired Pump guy.
Professional
Jan 6, 2010
1,726
216
Murphy, NC.
Solder on the threads??? This could be a real problem if the solder was put on in the proper manor. It won't want to all come off which is going to make that threaded fitting just a bit larger than it's supposed to be or smaller depending on what gender it is.
You do know that threaded fittings aren't soldered. Right?
Reedwalker
Expert Turd Herder
Professional
Jan 13, 2010
165
Detroit, MI
I think your answer is heat and patience. Also you may need a way to hold the fitting/nipple very steady while you hold the torch with one hand and wipe with a Jersey(100% cotton) glove. Turn 180* and repeat until you can get it to fit. You will not be able to sand away very much without screwing up the threads.
Good Luck!
havasu
Administrator
Staff member
Admin
Jan 5, 2010
10,171
1,864
Southern California,
In this case, a picture would be worth its weight in gold. I would not spend any time trying to clean this fitting and would just cut it off and replace the entire union (if possible).
phishfood
Professional
Professional
Lifetime Supporter
Jan 17, 2010
5,775
995
Orlando, FL
I would try heating it up and then using the brass brush on it. That is the most likely to reach down into the threads and pull the molten solder out. Compressed air also does a good job of this. The need for safety glasses is self explanatory.
majakdragon
Professional
Professional
Jan 7, 2010
297
Lafe Arkansas, Arkansas
You can try using a disposable flux brush. heat the fitting and then use the brush, with flux on it, to wipe off the solder. not sure why you have a threaded fitting with solder on it.
