Jordan Duff
Active Member
I just spent a few thousand dollars upgrading my main water line, meter, and adding a couple hundred feet of line/2 bury hydrants. I used 1.25” PVC on everything I did myself so that I would have plenty of volume. I had some pros come finish up, since I ran out of time with the trencher.
The plumbers that finished up installed 1” pex between my 1.25” PVC and the meter (about 60’), since I was upgrading my meter to the maximum of 1”. The meter got upgraded yesterday, and they used 1” pex as well to go from the street line to my meter (maybe 12’).
My whole reasoning for upping the size in everything was so I’d have plenty of volume, so that I could run the two new hydrants I put in at the same time with good output, and still have good pressure in the house. When I turned on the second hydrant yesterday there was a noticeable drop in the sprinkler pressure from the first hydrant.
I don’t know how bottlenecks work in plumbing, but obviously they’re going to restrict volume. The question is, how much? Would 1.25” PVC in the 60’ after the meter likely increase volume down the line, or would it be insignificant, since there’s already about 12’ of 1” from the city line to my meter? The total pipe from meter to last hydrant is a little over 300’, and as I said, it’s all 1.25” PVC, except the first 60’ (1” pex). Thanks for your help on this!
