Black Water
Discussion in 'Pumps and Wells' started by Beeston, Aug 15, 2011.
  1. Aug 15, 2011 #1
    Beeston
    Beeston
    Beeston
    Aug 15, 2011
    Seattle, WA
    Hello, this is my first post and i am seeking help for a water problem at my house. The water entering my system (from a well) is crystal clear. When it hits my pressure tank/sprinkler system is has a black tint to it and kind of smells of metal. PLEASE HELP! I will give any further information if needed.
  2. Aug 15, 2011 #2
    LiQuId
    LiQuId
    LiQuId
    Professional Professional
    Apr 13, 2011
    868
    15
    , Alberta
    sounds like you have a ruptured diapragm in a pressure tank.... replace the pressure tank.
    well experts here will give you other ideas if mine is bunk... though I am pretty sure this is your problem.
  3. Aug 16, 2011 #3
    speedbump
    speedbump
    speedbump
    Wells & pumps; not a... Professional
    Jan 6, 2010
    1,723
    212
    Riverview, Florida
    Yup, could be the tank. What kind of tank is it? If it's a bladder tank, what brand? If it's a galvanized tank, do you know if it has a float inside? Do you have a chlorinator?
  4. Aug 16, 2011 #4
    Driller1
    Driller1
    Driller1
    Jan 6, 2010
    83
    , Michigan
    I was wondering how you know it is clear going into the tank.
  5. Aug 18, 2011 #5
    Beeston
    Beeston
    Beeston
    Aug 15, 2011
    Seattle, WA
    Bladder, The brand is a flotec. I know it is clear because it splits of into to separate systems. One for our main house and one for a rental. The rental's water is perfectly fine. We do not have a chlorinator but currently thinking of getting one. Could Anaerobic bacteria be the problem?
  6. Aug 18, 2011 #6
    speedbump
    speedbump
    speedbump
    Jan 6, 2010
    1,723
    212
    Riverview, Florida
    The tank is bad. All you had to do is say Flotec. They typically last about 1.5 years. When the bag tears, the water gets into an unpainted metal tank that will start rusting rapidly and will mess up your water.
    It can also shorten the life of your pump when it gets waterlogged.
Share This Page
