BFP DISCHARD
Tamas
Aug 29, 2014
61
HI
IN MY COMMERCIAL PROJECT THAT HAS 1" BFP ON THE SERVICE LINE,
WHAT KIND OF PIPE-MATERIAL SUGGESTED TO USE FOR DISCHARGING BACK FLOW WATER TO AN APPROVED LOCATION???
This guy again.....talk to your AHJ, they can help best.
Are you dealing with an RPZ?
Drain should be of a material acceptable for gravity drain lines, as far as I know.
Don't forget the drain must be sized for the maximum possible flow, which can obtained from the RPZ manufacturers.
usually your air gap has female threads on it what are you using it for is there a floor drain near that wont cause a tripping hazard I have where is it located????
