Best Drain Cleaner
Discussion in 'Plumbing Products' started by vegaschk, Aug 27, 2010.
  1. Mar 7, 2013 #21
    Hockiologist
    Hockiologist
    Hockiologist
    Professional Professional
    Feb 21, 2013
    12
    Go ahead take day off from work,spend 40 or 50 bucks on junk then call a drain cleaning professional after hours since you spent all day monkeying with it and he can clean the original blockage plus what you have put in it ! Lol
  2. Aug 18, 2013 #22
    Matt30
    Matt30
    Matt30
    Jan 17, 2012
    2,112
    811
    Halifax, Nova Scotia
    I have finally found a drain cleaner thats worth a damn.
    I am not a regular user, im a fan of using the snake. But last week i came across 2 urinals that had so much calcium build up and scale in the traps that my snake couldnt bust it up on its own.
    I tried this chemical cleaner called Liquid Lightning. While it didnt solve the problem on its own, it made the scale and build up brittle enough that i could penetrate it with the snake and get it clear. Kind of like a tag team effect and it didnt harm the porcelain.
  3. Oct 17, 2013 #23
    LanceBC
    LanceBC
    LanceBC
    Sep 12, 2013
    Hey! Good to know, I'll have to write down the name. We use a product called 'Scoot' and it's pretty effective much in the same way
  4. Oct 19, 2013 #24
    stevemachine
    stevemachine
    stevemachine
    Senior Member Professional
    Jul 21, 2012
    869
    114
    edmonton, alberta
    I've used javelin's urinal drain cleaner for the same effect matt. It definitely works. Good to know
  5. Oct 31, 2013 #25
    whizeazz
    whizeazz
    whizeazz
    Oct 31, 2013
    5
    http://ecx.images-amazon.com/images/I/41+c4k5nkdL.jpg
    http://www.amazon.com/dp/B000MWWEDM/?tag=skimlinks_replacement-20
    I had a reoccurring back up that no harsh chemical would fix. I eventually had a plumber come and it would up being my trap leaving the house. he used this to clean the main line to the street anyway. I later had another back up from under the concrete so I bought this rather than call the $300 plumber. I could not be more satisfied. It hooked right up to my Homelite power washer i bought this year from HD and I was able to get from any vent to the trap. Definitely a 2 person job (my wife pulled the trigger while i managed the snake) the high pressure jets shoot backwards at a 45 degree angle which self propels the nozzle. Only thing you have to do is feed the hose and play around with it to get it to make the turns. I had one 90 turn a few feet into the vent then the rest was easy. Definitely recommend this product for clogs and general maintenance.
  6. Jan 2, 2014 #26
    chiraldude
    chiraldude
    chiraldude
    Hardcore DYI-er
    Nov 16, 2013
    126
    27
    Southern Minnesota
    Ok, here is the skinny from someone with knowledge of chemicals. (I have degrees in Chemical Engineering and Molecular Biology)
    Lye is the old standby drain cleaner. It breaks down grease and hair. It works but is slow. Most drain cleaners on the market now have added chlorine bleach with the Lye and most also have a gelling agent to make them cling to pipes for better effect.
    From chemistry side of things, Lye does not hurt pipes. Both cast iron and PVC are not affected by Lye. Might be corrosive to copper but very few houses have copper/brass drain pipes.
    The Chlorine in the bleach mixtures could be thought of as corrosive to cast iron but no more than salt water would be.
    Yes, if you don't handle these chemicals with care, they can be dangerous but if handled correctly, they will dissolve hair and grease clogs without harming the pipes.
    The enzymatic cleaners should work as well but they take days or weeks (or months?) to work. I actually tried to find a "good" enzymatic a while back but couldn't. What I found was that most of them are snake oil, containing little to no actual enzymes.
    As far as using sulfuric acid goes, that could be dangerous. I would never use is to clear a drain.
    Mr_David likes this.
  7. May 17, 2017 #27
    Marvelson
    Marvelson
    Marvelson
    May 16, 2017
    I mix vinegar and baking soda when cleaning the drain. I do it on a regular basis to avoid experiencing worse problems in the future. So far, it works. I avoid the use of chemicals drain cleaners too.
  8. May 23, 2017 #28
    Equiparts
    Equiparts
    Equiparts
    Plumbing and Maintenance Distributor
    May 23, 2017
    When you must use a drain cleaner, we recommend a Non Acid Drain Opener. See the dry chemical you mix with hot water that works to dissolve grease, hair, and other organic materials.
    RetiredCarGuy likes this.
  9. Jun 6, 2017 #29
    MarkC
    MarkC
    MarkC
    Jun 5, 2017
    Ft. St John, BC
    I'd have to agree with the general consensus here, go to the hardware store and buy a snake, you can even get cheap plastic hair pullers that work wonders for some cases.
    Such as this (Picture)
  10. Aug 23, 2017 #30
    timixon
    timixon
    timixon
    Aug 23, 2017
    Most household drains are composed of PVCs. When harsh chemicals are used as in cleaning the drainage it produces heat that can soften the pipes. Vinegar and baking soda works just as effective as this chemicals it does not only dislodged foods in the crevice but it also deodorized the foul smell that is of an issue when it comes to drains.
  11. Dec 30, 2017 #31
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Keeping It Simple Retired Guy
    Feb 2, 2015
    10
    , New York State
    I’m dealing with a severe kitchen drain blockage, in my own home. The iron drain pipe (2") is on an exterior kitchen wall, and very hard to reach under the sink. This current very cold weather keeps the pipe much colder. The blockage seems to have moved about 6 feet down the pipe. I’m continuing repeated very hot water treatments, heated on my wood stove, to push or hopefully dissolve it. I did break through it by a drain snake, but not enough to fully clear it. Now it is very slow.
    Are there any other specific drain cleaner, auger tip or method recommendations? Many thanks and Happy New Year!
  12. Dec 31, 2017 #32
    Matt30
    Matt30
    Matt30
    Jan 17, 2012
    2,112
    811
    Sounds like having the line professionally cleaned with a hydro jetter is your best option
    RetiredCarGuy and SHR like this.
  13. Dec 31, 2017 #33
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    Most consumers using liquid cleaners don't know what type of drain pipes they have. There are a lot of systems that are old DWV copper and old rotten cast iron.
    maybe in your neighborhood. Here in southern California plastic drains systems are ABS. Older homes are DWV copper and cast iron.
    Chemicals like sulfuric acid can generate a lot of heat that can distort plastic pipe if not used properly. they'll take the finish off your fixture as well.
    NEVER use them in a drain that is 100% blocked.
    When using an enzyme cleaner you have to use them on a regular maintenance schedule. Like taking antibiotics for an infection. You just can't take a couple pills and call it good. They consume organic material slowly.
    Just about every plumber you ask about chemical drain cleaners, most will tell you not to use them. They sell a lot of that crap and it does work SOMETIMES. but it's usually just a temporary solution.
    I get this a lot. I don't really put anything down my disposal. But every time you rinse off a dinner plate, oil and organic material get rinsed down the drain.
    Eventually sticking to and coating the inside of the pipe.
    using the disposal in moderation is like eating plenty of fiber in your diet.
    It helps scour the pipe clean. better done on Plastic systems.
    Cast Iron is another thing. It has a tendency to form very hard deposits on the inside.
    Even after cleaning with a snake and having to cut that section out, only a small 1" opening was mad with the snake.
  14. Jan 1, 2018 #34
    RetiredCarGuy
    RetiredCarGuy
    RetiredCarGuy
    Feb 2, 2015
    10
    , New York State
    Thanks Matt30 and Mr_David! I appreciate your excellent advice and concern.
    After a full day of near boiling water added every hour from my wood stove, with only minimal improvement, I just added Pequa for a 3 hour soak. Then afterward tonite, another hot water flush. If there is no significant improvement, tomorrow morning, I'll again fully disassemble and take your fine advice. Thanks again!
  15. Jan 3, 2018 #35
    SHR
    SHR
    SHR
    Member Professional
    Mar 5, 2014
    643
    294
    , Minnesota
    Please tell us this was a joke post to jab at Mr_David for warning you not to do it...If not, haz mat precautions will have to be taken by anyone going near the drain.
  16. Feb 19, 2018 #36
    brians356
    brians356
    brians356
    Apr 3, 2014
    14
    FWIW My plumber of over 30 years recently gave me a tip. He said if I pour 1 gallon per month of common distilled white vinegar (5% acid) down my tub drain, I will never get tree roots in my main sewer line again. To start he had me do one gallon per week for 4 weeks, then 2 gallons the next month, then 1 gallon per month thereafter. I started a couple of years ago, and so far so good.
  17. Feb 19, 2018 #37
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,316
    1,309
    Southern California,
    Many folks I know throw gallons of vinegar down their drains on a weekly basis. They believe it keeps the pipes smelling fresh. I think you are just throwing good money down the drain. Tree roots will always go to a water source, with vinegar or not. Yeahs ago, I had a plumber request I dig out my main line and throw (10) 50 pounds of rock salt around the perimeter of the pipes, but it probably would have been cheaper just to get rid of the clay pipe and replace it with a full length ABS pipe, where no root penetration could attack it.
  18. Feb 19, 2018 #38
    brians356
    brians356
    brians356
    Apr 3, 2014
    14
    Here was a plumber for many decades, with a great reputation in my town, telling me something which, if it works, would erase a significant portion of his business (as he admitted.) He told me none of his customers who had required rooting every year or so, then followed the vinegar treatment, had required root service thereafter. There are several possible explanations for his behavior, but, applying Occam's Razor, the simplest explanation is that he's telling the truth, and it does work.
Share This Page
