Bathroom toilet leak
Simard
Jan 2, 2023
Sorel-Tracy
Hello, I've been trying to install my toilet unsuccessfully.
What i've done so far :
- Replaced the drain system and the toilet flange ;
- Tried 2 different type of wax sealing (normal size and jumbo size) ;
- After my 2 attemps I found a crack on the toilet which is leaking water and that the leak on the floor is on the same side ;
At that point, i'm wondering if the water going in the subfloor is coming from the crack and goes into the toilet base hole or if its coming from the wax sealing or both.
I don't know if someone could tell me if it was properly scelled with the pictures i have?
Thank you!
Congratulations on discerning that there was a crack. Many people easily miss that, but is is not uncommon.
What 2wax says is the right call. Sorry. Check mfrs warranty if appropriate.
