musicfreak
Hi guys,
I wanted to take out the stopper of the pop up assembly as I was tired of my hair clogging the drain. I watched some youtube vids and thought it would be EASY to do. NOT! Ever since it has been leaking underneath the taps. I don't know if it comes from one of the taps (I think it does?) or the centre where the clevis goes.
I should have paid more attention when I put it back together because I probably put the clevis backwards which made a huge leak. I then turned it around and after fiddling with it a few times it is still better but still leaks. I don't know why but it doesn't leak all the time. It's like something isn't line up properly inside the tap where the clevis rod inserts. I just turned the tap water on for 5 mins and nothing happened but it was leaking yesterday. That always happens. It can leak worse when I hook up the washing machine.
I never use the pull up lever so it's not an issue there.
If the suggestion is to take the tap off I'm scared to do that in case I don't put it back properly and cause more leaks!
I notice if I look up the drain underneath I can see the bathroom lights through a small hole but that doesn't explain why it only sometimes leaks.
I also found when I put the clevis behind the supply hose it didn't leak as bad. Don't know if it matters if the clevis is behind or in front of it.
Please advise what the issue is. I can't seem to find it on google/youtube when I search for pop up assembly install/repair. And anything else I find about leaks is to do with the supply lines or pipe and that isn't the issue. It all started after I took the pop up assembly apart. I really wish I didn't watch the youtube vids as all I had to do was unscrew the nut a little and unhook the stopper!
I would like to fix this myself if possible as I'm scared my landlord will get pissed off because he will know messed with it. Or is it possible if he looked at it he would not assume I did anything as if that's the case I'll ask him to fix it!
I've added pics below. Sorry if they aren't better quality. If you need better ones let me know.
Thanks.
Thanks.
