I believe most 2 inch pipe size shielded couplings will be around 2.5 inches long, no matter what the specs say on sites like Home Depot.
They are much shorter than a typical black synthetic rubber coupling, in my experience.
You need to go up a size in diameter, because you will be clamping onto the hubs of two fittings, which are bigger than the named pipe size.
If this does not make sense, it will when you buy the wrong size, and have to return for what I said to buy.
FYI, sometimes it helps to file off any raised lettering on the hubs, to get a better seal.
Quick and dirty, if you don’t agree, no problem.
