Cambelious
Hi....
So I am currently working on converting my basement half bath (Toilet & sink) into a 3 piece bathroom (shower, toilet, and vanity). My house is a 1972 bi-level home near Vancouver BC, Canada.
When I ripped up the old bathroom, I found a basement floor drain under the bathroom floor. Around the drain (about 2 feet radius) there was a lot of dirt. I jack hammered the floor up around the drain and found the floor drain was connected to a black corrugated pipe. The pipe is filled with dirt and is cracked near the floor drain. (See pictures)
Now, on the other side of the wall (about 1 foot away from the drain) is the stack. I felt around the corrugated pipe to see if it goes towards the stack but it seems like it goes outside.
I am trying to understand how everything is all connected. In the attached picture you can see a 3" ABS pip running towards the stack. This pipe drains fine and doesn't seem to have any issues. Also, the water around the floor drain doesn't smell at all so i don't think any sewage is leaking.
Can someone tell me:
- Is the corrugated pipe attached to the weeping tile outside?
- Could the corrugated pipe be part of a internal weeping system?
- if it is attached to some sort of weeping system, why is the basement floor drain attached to the weeping tile, and not the stack?
- What should i do about drain pipe? Can I (somehow) attach it to the stack?
- Should I be worried that it is filled with dirt?
Thanks,
Danny
Thanks,
Danny
