Harold Veeder
- Joined
- May 11, 2023
- Messages
- 1
- Reaction score
- 0
My deep water well pump seems to be working OK. How ever the pump is short cycling. It seems most times it is due to a bad bladder in the pressure tank. I tapped the tank and hear a hollow sound on the upper third of the tank. The schrader valve is totally corroded and I cannot check the air pressure.. What other tests can I run before I replace the tank? I was thinking of installing an "emergency tire valve" so that I would be able to check the pressure.
