cmac2012
- Joined
- Mar 20, 2018
- Messages
- 87
- Reaction score
- 4
One of my client's house is in a nice hilly community, toney but not far from I-280 which goes through some otherwise exclusive property. Their street has a bit of hill action stopping most of the freeway noise but there is a bit of roar nonetheless so they put in a waterfall for some white noies. It's maybe 20 feet long emptying into a 15 foot diameter pond, this in their inclined front yard. It has three little creek/waterfall bits, one goes alongside the sidewalk which descends from the street to the front door.
It's surrounded by bushes and trees, about once a year I need to clean the scum and mud from the gravel and filters, as the flow gets progressively slower. This year I was having a weird problem, it would start to flow after I put it all together and then would go to next to nothing after a minuter or so.
I finally discovered that the backflow preventer just above the pump had failed - the spring mechanism that held the plastic plug had deteriorated, allowing the plug to be pushed up to the top.
There is another backflow preventer at the control panel, which has valves for the flow between the three rivulets to be balanced. Total rise maybe 10 feet.
They want this thing together now and the soonest I can get a new part is a week - not Amazon Prime capable, no one has it locally. I'm wondering if backflow protection is needed. I could get the plug out with some work. This is a completely closed system. I refill the pond with a garden hose after cleaning. All I can imagine the backflow preventer doing is keeping the weight of the water off the pump when it's not on which is about half the day - on a timer. Hard to imagine that is really needed.
Pretty sure this is the part:
https://store.aquascapeinc.com/p/check-valve-assembly-3
Here is a photo of the existing part, worn but plently servicable just as an elbow:
