American standard fill valve
Discussion in 'Toilets and Sinks' started by Haze196, Feb 11, 2019.
  1. Feb 11, 2019 #1
    Haze196
    Haze196
    Haze196
    Nov 18, 2018
    New jersey
    Looking to find out if this valve is adjustable.
    It's in an older low profile toilet and the level is too high and water is leaking out around the handle.
    I don't see any obvious means to adjust water level.
    Any help would be appreciated, thank you in advance.
  2. Feb 14, 2019 #2
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,471
    262
    North Reading, Mass.
    Did you try turning that knob on the top?
  3. Feb 14, 2019 #3
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    1,433
    210
    Boston, Massachusetts
    that cap may be were the rubber diaphragm is I have change other flush valve brands and the diaphragm was a(fluidmaster #242 disc) I cant tell if that cap raises or lowers the water level you would think there would be arrows to increase or decrease the water level
  4. Feb 14, 2019 #4
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,433
    210
    t
    changing that diaphragm may fix the issue
  5. Feb 14, 2019 #5
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    1,433
    210
    that fill valve is not a common one you would have to take the numbers off the inside of the tank and bring it to a plumbing supply house home depot/lowes would not carry it
  6. Feb 21, 2019 #6
    Haze196
    Haze196
    Haze196
    Nov 18, 2018
    New jersey
    Thanks guys, I will go back take another look. see if I can find any numbers on it
Share This Page
