BobJackson
Hi everyone,
If anyone has the time to read through this and can offer any advice or recommendations it would be very helpful, and thank you in advance for any info on this.
We've just bought a UV water filter system to run our well water through. Actually the term "well" is generous. We bought a house late last year and our water comes from a slow spring that empties into an extremely shallow cement basin (another project in the next couple years), which is then pumped into the basement into a holding tank. The "well" is not really sealed and as it is now can't be. There is evidence of mice around the well (nothing serious), and also the water may sit in the indoor holding tank for a few days depending on our water usage. For these reasons we just want the peace of mind of having clean tap water.
The system we bought has a pre-filter and then the UV canister. Luckily the shop that came with the house had some random copper pipe and fittings, so I bought a solder and flux kit and practiced on that already, and feel comfortable with the actual process. My main questions are around pipe size and valve differences.
For starters, our indoor water holding tank runs through a very short 1 inch PVC pipe into a jet pump. The pump has a 1/2" PEX line coming out that splits in two and goes to the hot water tank and a network of pipes for the cold water. I think the PEX is new to the more recent basement and addition to the house, so I'm guessing all the plumbing in the house is a mix of PEX and copper. The UV system will go in right after the jet pump before the line splits. The manual with the UV system only mentions 3/4" pipes to connect everything, but also says "you may need different fittings if your pipe size is different". The whole UV system will be sandwiched in between 1/2" PEX lines, so I have no existing copper to match sizes with (not that it would really matter). The other thing the manual mentions a couple times is ball valves for the various shutoffs and bypass line. But, in the diagrams it shows the typical round-knob valves that basically every hose faucet has on the side of a house. The only "ball-valve" options I can see at the hardware store are the red-handle 1/4 swing type. I'm assuming the actual look of the handle (round vs. straight) doesn't matter, and it's just that my local place doesn't have round-handled ball valves? The only round-knob types they have are compression valves, which as I understand use a rubber gasket to press down inside and stop the water. I've done some searching and see people saying each is better. Ball valves can't be fixed, but last longer. Compression valves can be fixed, but might not last as long. The one other thing with these valves is that I can get them with threaded ends or just flat ends for soldering. When I went to buy these I figured it would be more straight forward (I don't have any plumbing experience). What is the purpose of a threaded valve if all copper pipe has no threads and would need a threaded end soldered on, just to then be taped to a threaded valve? Wouldn't it be stronger to just solder the pipe directly to the valve? The one other option I was seeing with valves (only the compression type if I remember correctly) is that there were options with a small drain, which kind of resembled a burst valve. I don't think I would ever need this (I'm already going to be connecting a drain below the UV filter for when the bulb needs replacing), but they don't have enough valves without this drain. Is it a bad idea to buy a valve with a potential extra failure point if I'll never use the drain?
Finally, the main two questions I have are about the copper pipe size used to connect all the water filter components, and the type of valves to use. If the PEX lines coming into, and running out of the filter system are 1/2", is there any benefit to using 3/4" copper on the actual UV system? I've read in similar situations (minus the UV filter) many people say no, because the input line is already 1/2". I've seen people say going up in pipe size can lower water pressure too. I'm not really concerned about that though because the line drops back down to 1/2" right after the filter system. My thought is, could 3/4" pipes within the filter system slightly drop the pressure within the system, causing the water to move slightly slower past the UV lamp before hitting the smaller 1/2" PEX and then being forced back to a higher pressure? This is my uneducated guess. My other thought is that the jet pump pushes so hard that the 3/4" lines would be pressurized just the same as the output 1/2" PEX, because the PEX would create some resistance where the 3/4" ends and cause the small amount of 3/4" copper to build up the same pressure as the 1/2" PEX.
For the valves, should I spend the extra $30-$40 and get the 1/4 turn straight-handle ball-valves, or just go with the cheaper compression valves? It's not so much the price I'm concerned about, but more the physical size of the valve. The valves will be seldom used, and the round-handle compression valves just don't have those the big handles sticking out. I suppose the threat of them catching on something is minimal though. The other thing with the valves (more so than the copper elbows) is the price difference between 1/2" and 3/4". My decision on the final pipe size will really affect the cost of the valves.
Thank you so much if you read all that. I'm grateful for any advice on this setup.
