Acceptable wet vent??
Discussion in 'General Plumbing Help' started by Skot pearson, Jun 24, 2019.
  1. Jun 24, 2019 #1
    Skot pearson
    Skot pearson
    Skot pearson
    May 28, 2019
    14
    Maine
  2. Jun 25, 2019 #2
    Skot pearson
    Skot pearson
    Skot pearson
    May 28, 2019
    14
    Maine
    The dishwasher drains into the disposal. I would be tying the clothes washer below the kitchen sink/dishwasher inlet and above the bathroom inlet.
    I have heard that I may need to separate the sink and dishwasher drains, creating a trap arm for the dishwasher
  3. Jun 25, 2019 #3
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    321
    91
    83467
    The dishwasher needs to go up, to an air break, before it goes down to the garbage grinder. I like the deck mount air breaks, because you can see if there is a problem. It also keeps ground garbage from back feeding into the dishwasher.
  4. Jun 26, 2019 #4
    breplum
    breplum
    breplum
    Professional Professional
    Nov 14, 2017
    304
    120
    Lafayette, CA
    It will be ok if you do it as drawn. Assuming that vent stack is vertical.
  5. Jun 26, 2019 #5
    Skot pearson
    Skot pearson
    Skot pearson
    May 28, 2019
    14
    Maine
    Ok so tying in my clothes washer (3 fu) under my sink/dish washer's trap arm making a wet vent totaling 4fu above the clothes washer is going to be fine
  6. Jun 26, 2019 #6
    gagecalman
    gagecalman
    gagecalman
    Nov 11, 2016
    68
    11
    Baltimore, MD
    I'm not a plumber. It might work but I believe wet venting is for bathroom groups only.
  7. Jun 27, 2019 #7
    breplum
    breplum
    breplum
    Nov 14, 2017
    304
    120
    Lafayette, CA
    Vertical wet venting is all about fixture units and UPC (908.1) doesn't mention bathroom groups.
    Bathroom groups come up in horizontal wet venting in the UPC and in the IPC under vertical wet venting, but I am not schooled in IPC and have no interest in pondering the differences. https://codes.iccsafe.org/content/IPC2018/chapter-9-vents
  8. Jun 27, 2019 #8
    gagecalman
    gagecalman
    gagecalman
    Nov 11, 2016
    68
    11
    Baltimore, MD
  9. Jun 27, 2019 #9
    turdchaser2000
    turdchaser2000
    turdchaser2000
    Mar 16, 2014
    10
    That’s fine it’s more like a common vent under the code will work fine as drawn under ipc you need to use a sanitary tee instead of a wye or else it will need to be revented
Draft saved Draft deleted
Share This Page
Group Builder
