ABS pinhole in Tee.
Discussion in 'General Plumbing Help' started by jcarhart, Jul 4, 2019.
  1. Jul 4, 2019 #1
    jcarhart
    jcarhart
    jcarhart
    Jul 4, 2014
    6
    There is a pinhole spraying water in my pressurized jet pump system where the heat cable goes into the line to the lake at the ABS TEE How can I seal the leak? If I depressurize the system, clean the leak area and apply ABS cement abs2.jpg will this fix it?
  2. Jul 5, 2019 #2
    breplum
    breplum
    breplum
    Professional Professional
    Nov 14, 2017
    210
    77
    Lafayette, CA
    After depressurizing, I would rough up as much of the area as possible with something sharp and emery cloth.
    Then, plan on laying on globs of ABS cement. Letting it set up hard and lay on more layers.
    It is important to let it set up because if it is too thick, the final layer will set, but the underlying layers will stay soft, as though it were still in a can.
    Keep an eye on this joint for a few months to make sure it worked.
    Rossando likes this.
  3. Jul 5, 2019 #3
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,448
    256
    North Reading, Mass.
    Didn't think ABS was used for continuous pressure applications.
    But in any case, I would consider a patch using solvent welding (cement) a temporary fix and as advised by breplum, keep an eye on it.
  4. Jul 5, 2019 #4
    jcarhart
    jcarhart
    jcarhart
    Jul 4, 2014
    6
    Thanks. Am I correct in using a few thin layers of ABS solvent /cement rather than thick layers. How long in between layers? Should I use a hair dryer to speed curing?
  5. Jul 5, 2019 #5
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,448
    256
    Not that I have any first hand experience with this, multiple thin layers make a lot of sense to allow faster drying time. Although the main ingredient is likely the solvent, solids are included that are likely ABS materials, which should act as the patching material in addition to the first coat(s) that should help weld the pipe material at the pin hole somewhat. It makes sense but does, I believe, rely highly on the first coats adhession to the pipe.
Share This Page
