60" tub in a 60" alcove
Discussion in 'Showers and Tubs' started by craig2018, Feb 13, 2018.
  1. Feb 13, 2018 #1
    craig2018
    craig2018
    craig2018
    Feb 13, 2018
    Hi all.
    I'm remodeliing the bathrooom of a home constructed in the early 1960s and would like to install a 60" cast iron tub (Kohler Villager) in a space that seems to be just barely 60". This room appears to have been redone at least once as the current tub is fiberglass and the sub-floor (seen from underneath) clearly has been cut/patched. Anyway, the room is barely 60" wide, tubs are 60" and I'm hunting for the insight of pros to fit a tub into this spot. Any help is appreciated.
  2. Feb 13, 2018 #2
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    440
    86
    Mansfield,, Ohio
    How are you measuring it. From stud to stud or existing drywall to drywall.
  3. Feb 15, 2018 #3
    craig2018
    craig2018
    craig2018
    Feb 13, 2018
    I'm measuring stud to stud. The existing tub is still in place but I've removed the shower kit/walls and so can measure stud to stud.
    After my first post a friend suggested standing the tub on end in the alcove and then laying flat by a combination of temporarily moving/removing non-load bearing studs and manuevering between the studs. Are these legitimate secret methods?
  4. Feb 15, 2018 #4
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    440
    86
    Mansfield,, Ohio
    Yes if you have room to move the studs that probably would be the best way to go since this is a heavy cast iron tub. If it was fiberglass you could of picked the tub up with two people and layed it in the cove flat and slowly let it down in between. Good luck on your project.
  5. May 11, 2018 #5
    twinsig
    twinsig
    twinsig
    Dec 16, 2017
    6
    Did you get this accomplished?
    I have the same situation, need to remove everything and restore the floor and tub as well, rather do that outside.
Share This Page
